tkcas01
Dec 07, 2014Explorer
JohnG3 wrote:
Bought a Flo-jet a couple years ago as we camped where there was a sewer dump about 120 feet and maybe 1 ft. rise. Use the 1 1/2 inch lightweight swimingpool hose. Dumped one holding tank, took a while due to start and stop because of overheating of pump. Needed to burnish the armature and replace the brushes. Not worth the trouble. Went back to the blue dump tank and several trips. Much easier and cheaper.
Of course these things have their limits. That's a pretty long run, especially with a rise. I've had no problems with an 80' horizontal run in 1" hose. It also helps to make sure the wire you use to feed it is heavy enough gauge based on how long the wire run is.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
