AlbertaNewbie
Jun 25, 2014Explorer
Harvey51 wrote:
Thanks, AlbertaNewbie! Calgary is a lot closer, about 800 km. shipping should be reasonable. I see a 100 watt kit with charge controller that looks about right for me. $300. Any advice on this? http://solarwholesaler.ca/shop/100-watt-12v-rv-boat-solar-kit-starting-at-296-89/
It's a kit that you will quickly outgrow and replace. Plus ifnyou are thinking $300 is all it is think again. You need to add grommet cc to battery cable, lugs, etc, probably at least $100 in material.
Research research research and then look at the controllers to start, and add panels afterward. For a decent base kit to build off of look at about $600, $300 for controller, $300 for panel, mounts wiring and accessories, based on our cdn costs.
Also check out wegosolar, very decent shipping rates vs anybody else.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
