JoeChiOhki
Nov 21, 2013Explorer II
past-MIdirector wrote:
Your oven thermostat is bad which is part of the oven control valve. Easy to change other than running the thermo bulb into the oven cavity. The control valve are not adjustable if oven is off by more than 50 degrees so since it goes right to 450 it's bad. Most appliance part store or RV dealers can order one for you if you give them the Model and Serial number.
Thanks, I suspected as much, I'll pop by our local parts shop with the info and get what's needed.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
