bigkenobsd
Jan 15, 2015Explorer
Hello Friends, Received the new converter in a timely fashion from Best Converters. The swap went smooth and the new converter is working fine.The one Thing I would make sure you do is identify and label every wire you remove.If you have the means, take a series of photos of your wiring for reference later. Thanks so much for the input you were so right Randy is the man and the converter is a perfect swap.
