mrilizarov's avatar
mrilizarov
Magnetek power converter
Hi all. I'm looking for assistance with trouble shooting my new smart light 1000 patio sensor lights. I wired the lights and the aren't functioning correctly. Tech support at "smart light" told me I would have to switch the wires on my converter to a non filtered power source. Can anyone help with? is it as easy as switching the wires to a empty fuse port???????
  • If you have an older MagTek 63XX converter then there's a special output to the battery and another output to the fuse block. If it's one of the newer 73XX series then the output of the converter is tied directly to the battery.
  • Some of the 12 volt DC sections have two power sources, one filtered and one non-filtered. Look closely at the fuse buss work.
    Yes, it could be just moving wire and fuse to other section.
    Which model of converter?
