Tambs
May 16, 2020Explorer
The output terminal (top-center, no wire on front, black wire on back) has 13.8V to ground.
The lugs inside the blue circle in the pic have 0V to ground, and 0V lug to lug.
Yes, the wire connected to the output terminal on the backside of the fuse panel looks black to me as well.
The black and white wires on the battery lug terminals on the front side of the fuse panel are snug. I'll check the back side tomorrow. I'm assuming the other white wire that disappears behind the panel is the feeder from the converter that is probably landed on the back side of the panel on the negative lug. I will verify this tomorrow as well,and make sure it is snug.
All of the fuses in the panel (including the 30A RP fuses) checked out with a light tester.
Thanks to all for the assistance. I'll update my findings tomorrow.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
