pianotuna
Sep 03, 2016Nomad III
Hi,
The Magnum fan is temperature controlled.
It will run on heavy charging.
It will run on heavy inverting.
What we don't know is if it will continue to cool the device during charging if the source of 120 volt power is removed and the inverter is on.
I do know the fan stopped as soon as I removed the source of 120 volt power when the unit was charging at 74 amps and the inverter was off.
We also don't know if the fan will continue to run if the inverter has be loaded down and then the inverter is turned off.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
