pianotuna
Sep 05, 2016Nomad III
Hi,
Magnum was charging at 74 amps. I shut down the roof air. I shut down the inverter portion. Then I turned off the generator. The Magnum remained connected to the battery bank.
Jframpey wrote:
PT, your failure occurred while using the converter section to charge from a generator? Shutdown the generator with no 120v loads? And poof - the magic smoke escaped? It remained connected to batteries with only parasitic 12v loads?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
