hbski
Sep 08, 2016Explorer
happycamper002 wrote:
Load sharing is unheard of, when two power sources of different formats like inverter and gas engine generator outputs being coupled.
Actually this is exactly what the hybrid inverters are designed to do
The Magnum remained connected to the battery bank. (Charging operation was still active. Charge current at 74 amps coming from converter. Where else would you get it from.)
the 74A charging current was coming from the Magnum hybrid inverter charger (MSH3012M if I'm not mistaken). The generator or shore power input goes to the magnum inverter first, then that gets passed through to the RV system bus. IF more that the shore power/genny limit is needed the Magnum can add additional inverted power to the incoming AC from shore power or genny.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
