MEXICOWANDERER
Sep 08, 2016Explorer
If the grass is red and the sky is purple I would believe load SHARING
Otherwise it's dull green grass and blue sky and the operation is load BOOSTING
Even load SUPPORT is misleading. The function of inverter paralleling is to assist a generator in the STARTUP of a load.
Such points as DUTY CYCLE must be applied toward the inverter. X time for X watts of paralleling support. Boosting startup is supposed to take place in seconds, not minutes or hours, regardless of the size of the battery bank. Check with OEM if you question this.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
