pianotuna
Sep 08, 2016Nomad III
Hi Mex,
Also "load support" is NOT voltage support.
There is no information about duty cycle, and of course, there probably is one.
MEXICOWANDERER wrote:
Even load SUPPORT is misleading. The function of inverter paralleling is to assist a generator in the STARTUP of a load.
Such points as DUTY CYCLE must be applied toward the inverter. X time for X watts of paralleling support. Boosting startup is supposed to take place in seconds, not minutes or hours, regardless of the size of the battery bank. Check with OEM if you question this.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
