hbski
Sep 09, 2016Explorer
MEXICOWANDERER wrote:
My main issue here is not the load start synchronization but the zero interlink communications of ONE ELECTRONIC GENERATED SIGNAL SINE WAVE which would insure
Remaining compatible with another.
Please explain to me how any switched sine wave device could recognize, analyze, and auto-fault if necessary if an incoming sine wave became mis-shaped (distortion), while subject to lead-lag source destination push or pull.
This requires a software management program. Am I missing something here/
While I'm sure it has some tolerance of THD, no one has said that you can feed it garbage and expect it to work.
And it does have some software as evidenced by the ability to network it.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
