Colo_Native
Nov 07, 2016Explorer
Sam Spade wrote:Colo Native wrote:
The main concern is getting the 6" air space.
What exactly does it say about the required space ?
I think you are mis-interpreting that, as it probably requires a 6" space above the unit, regardless of which way it is mounted.
Mounting it upside down then would require a 6" clearance above the "bottom".
it is 6" around the intake and exhaust. " Allow at the minimum, an airspace clearance of 6” at the intake and exhaust vents and 3” everywhere else to provide adequate ventilation." vents are on 3 sides
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
