- Colo_NativeExplorer
pianotuna wrote:
How many amps is the switch rated for?Colo Native wrote:
the switch is in I don't like big sparks.
switch is 600 amps the inverter is 267 amp - pianotunaNomad IIIHow many amps is the switch rated for?
Colo Native wrote:
the switch is in I don't like big sparks. - Colo_NativeExplorerthe switch is in I don't like big sparks.
- BoonHaulerExplorer
Colo Native wrote:
GordonThree wrote:
CA Traveler wrote:
haddy1 wrote:
My Magnum cannot be turned off and will drain the battery to 50 percent in a month. Therefore I added a shutoff switch.Colo Native wrote:
looks like bottom up. Now would you recommend the fuse and shut off be near it or on the other side of the wall by the batteries, Thanks everybody
Actually, it should not have a shutoff. Most are wired directly to the batteries. That way the charger will work any time that you are connected to shore power.
x2 on a shutoff. great for storage as well as maintenance to the batteries or inverter... less exciting that just pulling the fuse / cable and getting that nice arc when you install it again as the capacitors recharge.
I am putting a shutoff in because it is easier to turn a knob than having sparks
I'm a little late to this thread but the switch is the ONLY way to roll. - JiminDenverExplorer IILooks great
- westendExplorerLooks real nice. Good work!
- CA_TravelerExplorer IIIQuality job wire it up!
MrWizard wrote:
i like it,,, looks real good and well thought out
should be NO problems
Thanks this is 3 days of trial and error - Colo_NativeExplorer
pianotuna wrote:
How far from the battery bank is the fuse? Nice looking installation.
Maybe a foot or 18" - pianotunaNomad IIIHow far from the battery bank is the fuse? Nice looking installation.
Having RV issues? Connect with others who have been in your shoes.24,313 PostsLatest Activity: Sep 07, 2025
