CA_Traveler
Sep 30, 2013Explorer III
GordonThree wrote:Voltage sense would be a pair of small wires from the Magnum to the battery so that the Magnum knows the actual battery voltage.This would improve the charging and inverter low voltage shutdown in cases like mine where the unit is far from the batteries or cases where the wiring should be larger gauge.CA Traveler wrote:
2. The DC amp display is estimated on the AC input current and not on the actual DC current. For example my unit will display 100A when in fact it is charging at 80A.
3. A battery voltage sense for the charger capability is not possible.
Magnum wants you to buy their add-on battery monitor module so they can squeeze some more $$$ out of you. The BMK gives you a 500A shunt to measure DC current in/out of the battery down to the milliamp level. It also enables a bunch of other features.
Not sure I understand point #3 ... are you talking about state of charge estimation using the battery voltage? I think there are battery voltage based "rules" you can program into the charger if you are using the advanced remote, another up-sell from Magnum
My unit has the capability of selecting different battery types with different voltage points.
