Itinerant1
Apr 22, 2018Explorer
Freightguy wrote:
I have the manual, its pretty much usless. Call for service is their solution.
+24A is low as I had the max charge set low from being on shore power for such a long time.
I can't be the only one with questions after reading your OP then saying the manual is usless, there is a lot of info for settings if you understand what it's saying.
Which Magnum inverter/ charger do you have? You said there 2 are both inverter/ chargers ? How do you know what to set charging for when not sure what size bank you have? What are the remotes and are they for the individual magnums? You recently posted in another thread about auto start issues on a generator I'm guessing that's wired through one of the remote controls?
