dougrainer
Nov 29, 2014Nomad
Paul127 wrote:
Hi, the inverter is operating fine, the 120vac to the coach is not operating. I have 120vac into and out of the inverter buss bar but no 120vac in the coach while plugged into 30amp service at the CG. I checked the large 12vdc fuse OK - I am unable to find the 30amp fuses on the inverter itself
I have read your post numerous times and still have NO IDEA of your problem.
1. The Inverter/Charger has NO affect on ALL 120 in your RV
2. The Inverter/Charger ONLY affects the few 120 circuits that run THRU the Inverter.
3. You have an INPUT 120 romex wire and an OUTPUT Romex wire. Does the INPUT have 120 volts? Does the OUTPUT have 120 volts. Your posts do not make this clear. It appears from this post I have copied you DO have 120 in and out, which indicates your Inverter is NOT the problem.
4. Do you have NO 120 in the RV at all? Doug
