CA_Traveler
Nov 29, 2014Explorer III
enblethen wrote:There are number of available options.
Circuit breakers are optional?
ME 2012 Manual
I would check the incoming wiring to insure that the connections are good.
Have you checked your power management system to insure it is reading 30 amp shore power or have you tried switching manually?
Assuming he has the 3 CBs and the inverter works so the AC outputs and CBs are OK.
OP does the unit charge the battery? If so then the input AC is good and the problem is internal. If not check to see that you have incoming AC.
