dougrainer
Nov 30, 2014Nomad
Paul127 wrote:
Corkey05, yes I tried unplugging all three data lines from the inverter and letting it sit, no luck. I will reach out to tech support tomorrow. I don't understand how the system is wired, I have 120vac at the power distribution panel in the MH but not at the outlets. Confusing, I will have tech support explain it to me.
Paul
Disconnect the 12 volt power cable TO the Inverter and have No 120 power to the RV for 10 minutes, then reconnect the 12 volt battery cable and reconnect 120 power. THAT resets the Inverter. Magnum will NOT know how your 120 power distribution is set up. ALL Magnum can do is help you verify that you have 120 to the Inverter and how to verify you have 120 coming out without inverting. IF you have a bad Inverter 120 transfer switch, resetting will not fix that. Doug
