Paul127's avatar
Paul127
Magnum ME 2012 Inverter Charger not providing 120VAC
Hi all, the 120vac is shut down in the MH by the inverter. I have tried to reset the inverter to no avail. The inverter works fine but the reset on the charger does not. Troubleshooting in the manual only instructs to hold the reset button, any ideas or suggestion? I have 120vac from the shore pwr to the inverter - I have 120vac on the 50amp breaker at the pwr panel.
  • As Corkey05 said, you need to check the two output circuit breakers on the side of the inverter itself.
  • Hi, the inverter is operating fine, the 120vac to the coach is not operating. I have 120vac into and out of the inverter buss bar but no 120vac in the coach while plugged into 30amp service at the CG. I checked the large 12vdc fuse OK - I am unable to find the 30amp fuses on the inverter itself
  • RoyB's avatar
    RoyB
    Explorer II
    Might want to check out the batteries... Not having one of those integrated INVERTER/CHARGER units I am not familiar with how they all work. I do know an INVERTER has to have a large working Battery Bank source to produce 120VAC. A 2000WATT Inverter will want to draw over 160AMPS DC Current from your battery bank if loaded down with alot of applinaces.
    Roy Ken
  • There are two 30 amp "Push-Pin" breakers on the inverter itself. Are they both pushed in?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 27, 2026
