full_mosey
May 10, 2017Explorer
Please come back if you are able to set AGM-2 mode.
I have been running a MMS 1012 for three years with a RC-25 remote because it came bundled. I did some research on the MMS 1012 and came to the conclusion that the MMS 1012 did not have all the settings you are seeing in your remote.
My research found that the MMS 1012 switches from FLA to AGM-1 when the RC-25 remote is used. There are no other settings. I did add the RTS cable for temp-comp charging.
My telco batteries are spec'ed 14.4V charge and 13.5V float. The MMS is always wrong on the low side. I have plenty of smart solar to finish the job correctly.
Thanks;
John
Thanks;
John
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
