3_tons
Oct 19, 2021Explorer III
When using the genny, the inverter also goes into the pass-thru mode (as it does with shore power), but if I understand correctly, there appears to be no problem with the generator as the power source…IF so, then the problem seems related only to the shore power source…Note that both the surge guard and/or the inverter have the ability to either qualify OR reject the incoming AC power, and for some reason (possibly the shore power cord??) your set-up is qualifying only the generator..My guess is that the generator does not pass-thru the surge guard, which may point to the surge guard…
I had a similar problem whereby my pass-thru Prosine 2.0 would reject Genny power when I tried to run the Honda in the eco mode, however, the Inverter would qualify the generator when not in the eco mode…Pass-thru inverters can sometimes be fussy in this way…
3 tons
3 tons
