Gdetrailer
Oct 20, 2021Explorer III
strudeau wrote:
Update: All connections in the Surge Guard Transfer switch are good and torqued appropriately. Connection/hot/common/ground in main panel all good.
Decided to bring the system online slowly by shutting off all incoming power (breakers) and main 50amp. Turned on the breakers 30 amp for the inverter and then one circuit and I got inverter power. Waited, and brought all inverter circuits up, and all was well.
Next I turned all the circuits back off and then turned the 50amp back on at the pedestal. I have two 30 amp breakers labeled charge #1 and charge #2. I monitored my read outs on my Firefly /Vega Touch specific to the Magnum. When I turned on charger #1 it showed zero on the AC Input Volts. When I turned on charger #2, it initially showed AC input volts at 118, and that the charger had come on (float). After 45 seconds, it kicked off and my AC input showed 184 volts as it has in the past.
I tested both 30 amp breakers on the meter and they both are good.
I’m down to the shore power cord at this point, unless anybody has other ideas.
Thanks again
Scott
Try taking a reading of the voltages with a separate volt meter like a DVM.
If the separate DVM does not read the same voltage as your display when the fault happens then the issue is with your inverter/charger.
If separate DVM reads the same as your display (181V) then issue most likely is the shore cord connection (adapters?).
Personally, if the shore power cable is at fault, it should not take 45 seconds for the system to fail, it should be immediate shut down.. Pointing a lot closer to a failure of your inverter/charger..
