time2roll
Sep 23, 2019Nomad
bkf wrote:While plugged into utility power 30 to 45 amps is plenty. If you expect fast battery charging from a generator 60 to 90 amps would be better.
@time2roll, thanks. That's an interesting option. You have any thoughts about the size of charger? I've got 4x6v (wired series+parallel so 12v and ~460ah, I believe), but the batteries (for now, while we're not moving much) are just used for the lights, fridge, tankless water heater... not much. It'd be a lot cheaper to get a charger, that's for sure.
http://www.bestconverter.com/PD-9280C-148-80-Amp-RV-ConverterCharger
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
