BFL13
Apr 01, 2018Explorer II
Yes, use the amps. With AGMs you leave the charger at Vabs (by battery spec) until amps taper down to near zip, then go to Float. Time to get to there is a variable, doesn't matter how long it takes.
If you set the amps higher to account for loads, then it will be set too high if the loads are not on. If loads will usually screw things up at that point, you could split the bank and finish half properly while the other half does the loads, then swap. Once both halves done, you can go to Float on all. (Maybe have one of those "1,2, Both" switches in the set-up?)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
