jharrell
Apr 29, 2018Explorer
10.5 is low however from the Magnum manual on start volts:
Where should I set Start Gen Volts? The VDC start voltage must be high enough to not overdischarge
the battery, but low enough to keep from nuisance starting the generator. Typically,
the start volts is set at approximately 50% of the battery capacity. Since this is an inverter/battery
system, and the battery is normally loaded, the VDC used to determine 50% battery capacity
should be set lower than what is shown on typical battery voltage SOC charts (approximately
11.0-11.5 in a 12-volt system), which show the battery at rest (unloaded). A typical start voltage
setting would be between 11.0 VDC - 11.5 VDC for a 12-volt system.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
