Harvey51
Jan 16, 2016Explorer
Thanks for getting me out to check. The parasitic draw is an amazing 15 mA. I discovered my cheapo voltmeter plugged into the cigarette lighter reads half a volt low; it was only 0.3 low in the house (25 below C outside today) so the battery was only down to 12.4. Not so bad. The two year old alternator is providing 14.7 volts immediately after start.
I have one of those 10 watt solar panels and it should be of use now that the sun goes up to nearly 30 degrees at noon (we are at latitude 56 degrees) and it is actually sunny today. No direct sunlight on the driveway though, due to trees and a house. I did check out my old van last year when it failed to start. It turned out to be two things - an old connector for powering a tent trailer from the engine battery was drawing half an amp, battery cable had a poor side connection. When switching to post connectors I found one of the cables was corroded at its end. A new battery helped, too.
Still, it must be hard for the alternator to fully charge the battery on a 4 block trip after a cold start. Especially in cars with more current draw from gadgets like remote control door locks and alarms.
There ought to be a way to maintain the battery charge when parked away from 120 V.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
