PaulJ2
Sep 29, 2013Explorer
A 130A alternator is a common OEM size. I think you will find this is a "peak" rating of only a few minutes or so. It's continuous rating is about 50-60A, called a "duty cycle". Also the drive belt/pulley system is usually only designed for about that amount of torque without protest (squealing).
I have seen rebuilts with a warning label attached with "Install only on a vehicle with a fully charged battery or warrenty is void".
I have noticed if the alternator is physically small it's continuous output rating is also small. Size does matter.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
