enblethen
Dec 22, 2014Nomad
Not a good idea.
I would run the auxiliary battery not through an isolator but through a continuous duty relay operated by a hot in "run" position of the ignition switch.
Diode based isolators loose some power where a relay based isolation relay does not.
Run the relay off the chassis battery fused for around 30 amps prior to going to relay contact points.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
