ken_white
Jun 28, 2014Explorer
Mex, here is a good device to start with, probably 2 in parallel.
N-Channel Enhancement MOSFET
The voltage gate-source (Vgs) controls the current in the drain-source (Ids). In an N-Channel Enhancement FET, the more positive the Vgs goes the more Ids will flow.
If the Vgs drive is not high enough for a desired Ids, the device will act as a constant current series load and will limit current through Ids. So typically Vgs is over driven (made greater) so a much higher current is able to flow when used as a switch.
The drive circuit for Vgs may be a little bit of a challenge depending how you connect everything.
Let me know how things progress and I will help where I can.
Ken
EDIT: Mex, PM me your e-mail address and I will send you some educational files on FET's.
High side switching primer...
App Note
Ken
App Note
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
