BFL13
Jul 19, 2017Explorer II
Is it not easier to use the 12v charger inside the rig out of the rain and just clamp the charger's clamps to the battery lugs on the fuse panel? You still need to run an extension cord to the rig for the charger, but that could be run inside through the door.
I presume this is all because you don't wish to connect the shore power cable to the extension cord from the house, which means there is no power to the converter. If the converter is a plug in type and you can get at it, you could just unplug it and plug it into the extension cord and never mind the charger.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
