Naio's avatar
Naio
Explorer II
Mar 24, 2018
Manual charger question
Is broke or do I not know how to use it?
I picked up a Schumacher SE1052 on Craigslist yesterday. On the 10 amp setting, on a mostly full 12 volt gel battery (yes really gel, not AGM) it starts at 14.2 volts, and rises steadily, reaching 15.3v after 5 or 10 minutes, at which point I unplugged it.
On the 2 amp setting, different battery, also 12-volt gel, it starts at 13.38 and rises more slowly. Now, after 10 minutes is about 13.5.
I'm used to smart chargers. Is this how manual chargers work, or is it defective?
Thanks!
  • Do not use that charger on an AGM or gel. You will destroy them quickly.
    It sounds like it is working properly, but it is not an appropriate charger for anything but a conventional flooded cell, and even then you need to understand the charging process to know when to shut it down.
