Apparently the Iota can be opened up and has a Voltage Pot too. Not sure of all the details but apparently it has to be a model without the internal IQ4 thingamagiggywhosyseewhattseeyymabobber 'wizard' like device. Hope thats not too technical.
I think Mena's 105f limited Iota needs to have a new higher CFM high static pressure rating 80MM Fan turned around pushing air inside, and the Pot cranked upto 15 for effective bulk charging.
How hard can it be to solder on a new Pot to mount externally?
I want to do this with a MeanWell 30 amp power supply. Anybody know the range of the tiny fragile circuit board mounted potentiometer?
