Lynxlover's avatar
Lynxlover
Manual slde
Hello all, I am a new member. I hope I'm posting this in the propper area.
I have purchased a 1991 Kustom Koach Travelaire park model, serial number is: 2TT396FL5N1K20032
It has a 36 foot manual slide out that appears to have been put out and then the interior finished after, ie carpet etc. I beleive the unit is all original and stock from the factory. I need to move it 500 kms by April 15th no later. The cost to move on a dolly is high.
I would like to find someone who has experience with this style of unit to aid in getting the slide back in for transport. There may be walls etc that have to be removed...An owners manual does not appear to be available. would appreciate any info. Thank you
  • I'm confused........
    WHY is the post from 2011 and this post today the exact same...word for word?
    Post in 2011 had NO Replies/responses and was torino11 only post
  • Here's a copy of the original post from 2011. Right at the top you will see that the topic was closed... so you will not find any information related to the original question... unless maybe a moderator can dig it up.... ??
    This Topic Is Closed | Print Topic | Post New Topic |
    Sponsored By:
    torino11
    Alberta
    New Member
    View Profile
    Offline
    Posted: 02/22/11 05:27pm Link | Print | Notify Moderator
    pulsar
    Lewisville, NC
    Senior Member
    View Profile
    Good Sam RV Club Member
    Posted: 02/22/11 10:22pm Link | Print | Notify Moderator
    Moved from Forum Technical Support to Tech Issues.
  • I believe the person that originally moved this trailer from Alberta to Kelowna asked this same question back in 2011. I was wondering how to search back to 2011 to get an answer for this question that he originally asked
  • Hi,
    You may try contacting http://tripleerv.com/ in Manitoba. I believe they ended up with the information from the Kustom Koach line made in Redeer Alberta.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
