DutchmenSport
Nov 13, 2015Explorer
If you have a camper that has a slide on one side only, you level the camper and then put the slide out. The side with the slide out is now tilting down. To compensate, folks will figure out the difference with the slide out and slide in. Then, when parking, will put boards under the tires of the slide side so it raises. Then when the slide is extended, it becomes level.
If you get a camper with opposing side slides, you don't have the problem.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
