Locky
Mar 09, 2013Explorer
Theres numerous ways to do this. A couple already said above or try using the next size up screw and if that doesn't work then fill the holes with your caulk then install the lights with your screws even though they are stripped. Now caulk around the light like you would normally have. Once the caulk drys you will be fine.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
