camperpaul
Jul 17, 2013Explorer
Make an adapter plate out of 1/8" aircraft grade aluminum:
Drill and de-burr a 3/4" hole for the wires.
Drill holes for mounting the marker light; tap these holes for #8-32 machine screws.
Drill a set of four mounting holes in the adapter plate.
Wet sand the adapter plate with 600 grit waterproof paper.
Screw the #8-32 screws halfway into the tapped holes.
Paint the adapter plate to match your trailer. Remove the screws after the paint dries.
Assemble the light to the adapter plate with the machine screws.
Mount the assembly to the trailer with #10 sheet metal screws.
Done.
Done.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
