Cruiseomatic
Jul 19, 2013Explorer
Tried different mixing ratios on jb, same results. Cured hard as a rock in the wall but still soft on the outside. Aircraft aluminum is out of budget for now so what I'll do is get some beverage cans and cut to double the size I need for added thickness then rivet them inside the wall so when the screw pulls it pulls from the inside out. Even tried oatey fix it stick and it wouldn't stick to the siding. And I cleaned with acetone. OR, Would I get the same results riveting the new metal outside and running foil tape over the patch to prevent water intrusion? They will be painted over. Riveting on the outside side would be easier but I'm looking for structural integrity and shear strength. Any help would be greatly appreciated.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
