dan-nickie
Jun 12, 2013Explorer
pianotuna wrote:
Hi dan-nickie,
Since you were "in the business" what would you recommend for an external cover material? It has to be able to survive in Canadian winters.
I was planning on using industrial velcro as a fastener. Will that work for me at highway speeds, or am I asking too much of the product?
I use Suntex 90 Solar Screeen attached on the outside with these EZ Snapsfor the external heat blockage.
I do not leave them on when traveling and would not suggest it.
Although Suntex 90 Solar Screen is typically left on brick homes all winter without deteriorating, I wouldn't know about the -40 temperature you are asking about. Being from the south, I envision everything turning to crystal and shattering to dust at those temps. :)
I'm afraid you are not going to find a product that benefits both heat and extreme cold that you can leave on while traveling.
Good luck though. Something may be out there.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
