BFL13's avatar
BFL13
Explorer II
Jan 31, 2021
Math is Hard-- C Rate ?
I am confused about how many amps in a C rate, if anyone can explain that again. Thanks.
After getting the SiO2s late last year, I charged them to as full as they would get, which was at 14.6v with amps tapered to 0.5a /100AH same as ordinary AGMs spec. The SiO2 battery spec charging graph says they get down to "0.02CA" and then after more time to "0.01CA" as Full.
Does that "0.01CA" for Full mean 1 amp per 100AH? If so, that is twice the 0.5 amps per 100 with ordinary AGMs.
Meanwhile, after floating them at 13.3v--I picked that voltage as being not a full float in case I was not supposed to be floating them at all--still not sure about that whole thing--
They got charged yesterday (as a spot check) at 14.6v and amps tapered on the two in parallel (200AH) to 0.2 amps and stayed at that for a time, so I went back to float at 13.3 for now.
That is 0.1 amp each as their Full. Could "0.01CA" be a typo? When I had ordinary AGMs, I would see lower than 0.5a/100AH on them too.
(I assume that time floating did them some good, since they now taper to 0.1 each instead of that 0.5 when I first got them. I think I will keep floating them between trips, never mind what Trojan says.)
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
