- BFL13Explorer II
Chum lee wrote:
How well ventilated is your battery compartment, if one exists? In high draw conditions, wet cell (lead/acid) batteries will eventually off gas hydrogen and oxygen in large enough quantities to go boom. (not good)
Chum lee
AFAIK (?) there is no gassing on discharge. The hydrogen is combining with oxygen to make water.
On recharging you will get get gassing once the voltage rises to "gassing voltage" of about 14.2v and you get acid instead of water being made. - pianotunaNomad IIIPbO2+Pb+2H2SO4 -- ChargeDischarge -- 2PbSO4+2H2
BFL13,
If I am reading that chemical equation correctly Hydrogen is produced on discharge.
From;
https://www.sciencedirect.com/topics/engineering/sealed-battery - BFL13Explorer II
BFL13,
From;
The link says the last part is "2H2O" not "2H2" but it is confusing.
My Battery Bible--
http://www.bestconverter.com/Books_c_67.html
just says that on discharge, " the hydrogen ions in the electrolyte move to the positive plates and combine with the oxygen to form water---"
on recharging, "the positively charged hydrogen ions are attracted to the negative plates where the hydrogen combines with the lead sulfate to form lead and sulfuric acid. When most of the lead sulfate is converted to lead, hydrogen bubbles form at the negative plates and rise through the electrolyte.....oxygen appears at the postive plate when this process is near completion. the formation of the gas indicates the battery is nearing complete charge..." - pianotunaNomad IIIHi BFL13,
There was a slider--so I did not copy the entire equation--sorry about that! - Chum_leeExplorer
BFL13 wrote:
BFL13,
From;
My Battery Bible--
on recharging, "the positively charged hydrogen ions are attracted to the negative plates where the hydrogen combines with the lead sulfate to form lead and sulfuric acid. When most of the lead sulfate is converted to lead, hydrogen bubbles form at the negative plates and rise through the electrolyte.....oxygen appears at the positive plate when this process is near completion. the formation of the gas indicates the battery is nearing complete charge..."
Those chemical equations are "generalized" to simplify the learning process. In reality, there are many other side reactions which occur, especially as batteries age and the plates/electrolyte becomes contaminated. (with sodium, potassium, magnesium, calcium, iron, fluoride, chloride, iodide, etc. from using other than distilled water) Generally, it's true that when recharging lead/acid batteries, more gas is generated than when discharging. The point is, if you are going to discharge wet cell batteries at a high rate over an extended period of time, eventually they will need to be recharged. (probably at a high rate also) The battery compartment(s) need adequate ventilation. That's my point! Overlook that and eventually, . . . . . . BOOM!
Chum lee - MEXICOWANDERERExplorerMy fingers will not support a lot of writing. Sorry folks, but your excerpts are incomplete :)
BATTERY UNIVERSITY has had mutiple peer reviews including my own. I heartily endorse studying this free resource. - pianotunaNomad III
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
