pianotuna wrote:
I think we all assumed you were setting bulk/absorption.
Hi,
I was toying with my charge voltages. I wanted to try 15.4. When I set 15.4 on the remote it did not get above 14.7 volts. The bank was fairly full so it was only doing between 8 and 10 amps of charging.
Does anyone know the maximum dc output voltage?
I did post that there must be some other limit.- jharrellExplorer
pianotuna wrote:
So that I can do a recovery on the AGM's when that becomes needed. At 77 f (25 c) lifeline suggests recovery voltage for 8 hours @ 15.48 volts.
Did you look at using the equalization function? You can set voltage and hours, then you hold down the charger button for 5 seconds while in float and it will do the equalization charger, even had a reminder in days that can be setup. - pianotunaNomad IIIHi jharrel,
Thanks for that information on the equalize function. - gatorcqExplorerThe nice thing about Magnum, is the Custom Battery settings.
Once you ID the specific battery charge, you use the custom mode.
Next step will be Lithium - Magnum makes it very easy to setup.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
