wyocowboy00
Jun 06, 2017Explorer II
I found when putting together my solar system that it is easy to not get the connectors pushed all the way (and locked) into the MP4. Then when you put the MP4s together (plugged into each other), it pushes the connectors back and causes a bad connection. On my solar installation I had one of the leads from the roof to the controller wide open. It turned out to be a connector on a plug (about right in the middle of the wire run) that had not been seated corrected and got pushed out the back of the plug. You may have a connector that is just barely making contact.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
