MGFMONACO's avatar
MGFMONACO
ME2012 Inverter Problem
I do have a 2007 Monaco, my problem is my ME2012 Inverter don’t work properly. I have power on my fridge, microwave and outlets, but no power in my two A/C and ceiling lights, also no lights in my control panel. Someone has idea what caused this problem.
thanks
  • Is it a domestic fridge or an RV fridge. Domestics require only ac power.
  • have you checked all the breakers, it sounds like the inverter part isn't working to me from your description, if the ceiling lights are 120V.  if the ceiling lights are 12V then it is either a combination of the inverter and fuse, or it could just be pure fuse and brakers.  failing that, the trouble shooting gets way more involved
  • What makes you think it's the inverter?
    ON EDIT: I see now that the ME2012 is an inverter / CHARGER. It seems to me that the 12V part of your system is not working (though I'm confused by your fridge working - they usually require 12V). Have you checked the state of charge of your batteries?
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      He said AC, microwave and some outlets work. So assuming he’s running those off the inverter, it sure ain’t the problem if it will chill the camper and cook a hot pocket.
      But I’m skeptical if the OP knows what the inverter does and when it does it. He’s probably plugged into shore power when running TWO ACs successfully.
      But hey maybe it’s fixed since he/she hasn’t followed up. It’s this weird phenomena of thinking one can post some general gibberish with a question attached and those that would respond are like instant AI gratification and spit out the right answer while being clairvoyant to the things that weren’t mentioned or aren’t understood.
      It’s rampant with kids. Like mine. But also infecting old and middle aged people quickly. lol
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
