brulaz
Dec 15, 2017Explorer
theoldwizard1 wrote:
If your specs are correct, there is no reason it will not work. The limit on the power supply is 500W, so just divide that by the output voltage yo adjust it to and you will have a good idea of the amperage.
To properly charge a lead acid battery, you are going to need about 2.45V/cell or abut 29.5. 32V input is very close to that !
I've actually seen the Meanwell put out 700W according to the inverter feeding it. But with 90% efficiency and a setting of 32.5V, that should by around 20A max. The EpSolar should be able to handle that.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
