brulaz
Dec 16, 2017Explorer
This EPSolar Tracer 2210A limits its current Output to 20A (at 24V = 520W). But like BFL13 says it claims it can handle upto 3x that wattage as solar Input (1560W @24V).
The Meanwell RSP-500-27 as Input to the EpSolar is rated at 500W, but I've seen the Inverter feeding it briefly display 700W with depleted batteries. The Meanwell is constant current limited with a rated power overload of 105-130% of 500W. At 130% that's a rated max of 650W, about what I've seen taking into account the Inverter's inefficiency.
By setting the Meanwell Output to its max observed V of 32.5V and with its rated 90% efficiency, that's a max Output of < 20A at 650-700W. It's actual rated current Output is 18.6A. It is also current self-limiting and will not provide any more amps than that AFAIK.
At this point, I'm more worried that the EpSolar will somehow notice that the Meanwell is not behaving as a Solar Panel when it does its MPP scans; and freak out. As suggested by the Wiz, a PWM controller might be a better choice for this application. We'll see.
Sadly I will not be back at the trailer until early Feb to see if all this works. Will report back then.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
