BFL13
Feb 01, 2018Explorer II
So you got the temp comp for the Meanwell as desired in the OP, but what about the matching part? You can still run the Meanwell and the solar in parallel on the battery bank so they add their amps if you go Meanwell-battery direct instead of via Tracer. Is that a job for one of those 1-2 switches?
Can't remember how you power the Meanwell off-grid. With your inverter off the truck battery supplied by the alternator? Generator?
If gen, you can have alternator while idling, solar, and Meanwell all adding their amps
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
