BFL13
Feb 02, 2018Explorer II
If you are getting something new, this might be of interest. The LKs are apparently still being tried out in the marketplace. Don't have any latest info on where that all stands.
https://www.amazon.ca/Powermax-PM3-25-24LK-Power-Supply-Converter/dp/B01N5M3K5I/ref=sr_1_22?ie=UTF8&qid=1517578837&sr=8-22&keywords=PowerMax+converter
I have a proto-type 12v LK from 2016. It has an internal fan instead of the external fan like the PM3s and 4s, and has the two holes in the side for the neat feature that lets you adjust the voltage (with a small screwdriver) using the pot inside. There is a switch behind the other hole to swap between 3-stage auto and single stage but adjustable voltage.
I don't know if BoatandRV has other amp sizes in 24v. BoatandRV has a chat line on their website. I would be sure to get it absolutely clear direct from them what the story is with the 24v LKs to make sure amazon sends you the right one, since there have been some mix-ups in the past, what with so many different versions of these things right now.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
