Almot
Apr 07, 2015Explorer III
JiminDenver wrote:
I don't get the watt debate unless there is a huge difference in idle draw. ...I'll probably spent the money for the Morningstar 300w just because it is fanless.
There is usually a big difference in idle draw btw 300W and 1,500W. So, if you can get away with 200W fanless, why not. Doesn't have to be PSW. The only thing that "might" object to MSW is a TV, some of them do and some don't. AC bricks of laptop and other small electronics work fine with 200W MSW @ $20 or 30.
If you don't use popular kitchen gadgets, it's doable on 150-200W. But, as soon as you plug your toaster in, or microwave, or coffee maker, your power needs jump abruptly to +1,000W. There is pretty much nothing in between - other than soldering iron ;)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
