Freeway_Flyer_0's avatar
Jul 19, 2020
Measuring battery condition
Easiest way to measure battery level of charge?
  • If you install a solar system with a display, during daylight hours you can tell the SOC by the amount of current the batteries are accepting.
  • It depends on the type of battery, and few methods work for all types of batteries.
    You can't measure SOC with any accuracy using a voltage measurement on a Lithium-Ion battery.
    You can't measure SOC using specific gravity on a sealed battery.
    But if you start with what you know is a fully charged battery and use a permanently attached coulometer to measure the power in and power out, it will give you a pretty good idea of your battery's SOC at any point in time.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    best SOC indicator is measuring specific gravity with a calibrated hydrometer with temperature compensation. Look for a Frease (sp?) brand hydrometer.
    The cheap ones in the auto parts store are hit and miss
    If you want to know battery condition then after fully charging the battery to a load test.
  • There is the right way (install a proper voltmeter), and then there is my way -- I disconnect the battery. Let it sit for 15 min. Take out my little multimeter and hook it up.
    They say you need to leave the battery resting for quite a while to get an accurate reading. But I tried taking a resting reading after 5 min, 10 min, 15 min, 30 min., etc., and found that the reading was very close to correct after only 15 min.
    If you try to take a reading when the battery is connected to your RV, you will probably get an artificially low reading. It'll say 12.2 volts when it is really 12.5, for example.
